Posted by dave guest on July 15, 2008 at 20:36:38 from (4.229.177.104):
Feel so dumb. I gotta ask. Anybody ever remove condensor from AC? Have done this but not for 30 years. Is it likely I could remove it from the front of rad without removing rad and hoses and trans lines? Any tips appreciated. Really having trouble seeing how it is attached. Vacuum and charging no problem, but I gotta get started. LT 1 motor. Thanks mechanics!!! PS: I put the dye in and found a hole with purple light.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
