As far as I know, there is no dipstick for the hydraulics on a 400. You fill through the level plug on the side of the steering pedestal until it runs out.
Not sure what dipstick you're checking... Where is it located?
If the 3pt will go up and down through the full stroke, it's not a lack of oil, though.
The 3pt needs at least one 4" diameter x 8" stroke cylinder, or two 3" x 8" cylinders. With that and 750PSI (typical H or M pressure), I've seen them lift Super C-size tractors with the 3pt hitch, many times the weight of one of your bales. If you tried to economize and run a small 2" cylinder, it won't be able to generate the brute force to lift that much weight.
Do the hydraulics squeal when it maxxes out? If you get a squeal noise, with a big enough cylinder, the relief valve needs to be fixed. It should activate at around 1250PSI.
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
