Posted by riverbend on July 25, 2008 at 20:57:07 from (208.160.33.104):
In Reply to: H points adjusting? posted by kwm219 on July 25, 2008 at 19:06:38:
The Operators Manual gives instructions for setting the points. Set the opening point to 0.020" gap when the rubbing block is on the lobe of the distributor cam. If the gap is not correct, loosen the screw on the fixed point and move it until the gap is correct after you have tightened the screw.
Two things to pay attention to: 1) make sure that the points meet squarely. It is possible to twist the moveable point when you tighten the nut that holds the spring. 2) you have to reset the timing.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
