Thanks to everybody for the pointers. My tractor uses a mag. I"ve got the timing cover off so I can line up the timing marks. I"ve re-checked the new governor assembly for any suggestion of timing marks. There are none, and none on the backside either.
I put the old gov. gear back in place with all timing marks aligned and marked where the mag. drive slot was oriented (at about 2-8 o"clock looking from the rear). I then removed the old gov. and put the new one in and find that I can get the mag. drive slot to within about a degree of the marks I made. I"m thinking that I can now put the timing marks onto the governor gear and have it in the same position as the original.
I need to mark it since I also have to pull and replace the camshaft gear. Some of the cogs are broken, apparently from the half dozen or so cogs that were wiped out on the governor gear. I also hope to pull and replace the drive shaft timing gear too while I"m at it, though it wasn"t damaged, but is worn (if I can get it off!).
An additional question I have is, since I don"t have the shafts out (and don"t have a gear press), is it permissible to drive the timing gears back onto the shafts, say using a block of wood and light sledge? (Any likely damage to rear seals or something else?)
Thanks again for all the suggestions and pointers. I"ve had old "Short Stack" for almost 40 years, and this has been its first major breakdown.
Today's Featured Article - Fordson Model N: Field Service Operations and Lubrication - by Anthony West. The daily or weekly servicing of any vehicle is of the utmost importance, and in days gone by when our favorite tractors were doing an important and Commercially vital job on the farm, these service operations would make a major difference to the running costs and economy of the farm. This being so, it surprises me to see how many enthusiasts attending rallies, shows etc, seem to be unaware of the importance of this constant attention. Possibly the modern machine with its 6,000 mile or even once
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
