Another thought, following up on Jim's. To replace the crank gear, you're going to have to remove the pulley from the crank to get it and the timing case cover out of the way. If you happen to have a big puller and the head for it to fit around the groove in the pulley it can be done, but it can be a bear and is much easier on a press and less apt to break or ship the pulley. A regular two or three jaw puller will often just bust chips out the edges of the pulley without moving a thing, leaving you to have to replace that, too. That argues for taking it in to have it pressed off, at which point you might as well have the new gears in hand and have them pressed back on while you're there. And I can say for sure that, press or no, heat is a big help in getting the pulley off and back on.
The cam itself comes out pretty easily with bolts you reach through holes in the gear. Removing it does mean lifting your rocker arm assembly to get your push rods out beforehand so that the cam comes out smoothly. Not that much added in work in the context of what you're into already.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
