Posted by Wayne from MN on August 20, 2008 at 10:19:00 from (66.228.243.49):
In Reply to: Bull Gear M posted by moonlite 37 on August 20, 2008 at 03:29:18:
You need to remove the transmission cover to replace the bull gear. Be careful loosening the cover cap screws; blow all dirt away and carefully turn your socket handle both left & right until you are sure the cap screw is loosening easily. The belt pulley (if present) will need to be removed first. Shift the transmission to neutral. Unless you have a shop crane or loader, get 3 strong friends to help lift the cover off. Block carefully under the transmission housing and block the opposite rear tire so nothing is going to endanger you. Remove the tire-wheel assembly, loosen the axle housing cap screws, loosen the bull gear cap screw while placing a spacer between the 2 bull gear cap screws. This will force the axle out of the gear you are replacing. Needless to say, this is a good time to replace all the lube in the rear end; turn the belt pulley over to drain about a pint or so of old oil out at the same time. There is a small drain plug on the belly of the tractor under the belt pulley area that will drain the front housing area as well. Good luck.
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
