One more item!! If you replace the switch, make sure you check the thickness of the metal where the bolts pass through to hold it on. If it is any thinner than the original (any) the bolts will go into the starter and short out the field. (this info from other posts on this forum) Putting washers under the head of the bolt, or using appropriate shorter bolts works. (it is also a reflection of the lack of quality of some new parts. JimN
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
