Re: Knocking noise from belly of Farmall H
Posted by kippster on September 08, 2008 at 13:43:34 from (24.144.197.139):
In Reply to: Knocking noise from belly of Farmall H posted by Anthony SW MO on September 07, 2008 at 21:35:42:
I had that same thing happen to my H when I was harrowing last spring. I took the cover off under the clutch and was able to see up inside. There is a shaft inside of that little area behind the bellhousing, that turns kind of like a drive shaft in your truck. There are, if my memory serves me correctly, 4 bolts up there on that shaft that hold it together. All of mine were loose. I tightened them down good and tight, and the noise has not come back since. Boy I sure was scared, but it has held together for over a year using it every day for at least an hour or 3, sometimes all day long! Good luck!
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
