Re: Leaking 140...???
Posted by Hugh MacKay on September 08, 2008 at 16:10:36 from (209.226.106.139):
In Reply to: Re: Leaking 140...??? posted by KRS_MED on September 08, 2008 at 03:39:12:
Keith: One thing to remember with most tractors, and especially these offsets. When it comes to lube oils, too much is not better. If you operate the engine with crankcase overfull they will pop crank seals. Those don't stop leaking when you drain oil off. If you operate hydraulics overfull, it will pop a plug on front side of unit in behind front rochshaft. Full with hydraulics is always check levels with rockshafts in rear position.
The transmission-rear end and final drives are a bit more forgiving, they only leak as long as they are overfull. Bear in mind the seals can go bad, however there have been many a guy tore into changing seals when in fact overfull was the problem.
Steering box is a bit different, they leaked from the time tractor was 5 years old. Poor design is the problem. Best cure is install a grease zerk on drain or fill to level plug, pump in 3 tubes of grease, then add about 4 pumps every time you grease front end.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
