Re: installing valve seals
Posted by El Toro on September 09, 2008 at 14:27:59 from (64.12.116.73):
In Reply to: installing valve seals posted by john in pennsylvania on September 09, 2008 at 13:42:57:
You need to get each piston to TDC on the compression stroke so both valves are closed. You also need an adapter to fit in the sparkplug
hole threads so you can connect an air hose and use air pressure to keep the valves closed. They make a valve compressor or they did years ago so you can compress the valve springs and be able to remove the keepers and springs. Then you can install the valve seals. Then reinstall the springs and keepers. Be careful you don't drop one of the keepers. Hal
PS: I have one of those compressors.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
