The Super C used the 354898R1 block and the sleeves measured 7-1/16" in length and 3-7/16" in diameter at the seal. They came from the factory with 3-1/8" pistons and the block would accept an over bore kit of 3-1/4" pistons to boost the cid to 133cu-in. Your block I think is the C113cid and has had an overbore kit installed at one time to boost it to 123cid. The Super C's had water pumps too. Your sleeves probably measure 6-7/8" in length and measure 3-5/16" in diameter at the seal. Hal
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
