Farmall M Noise: Governor or Manifold Leak?
Posted by Kerwin on September 21, 2008 at 19:54:49 from (207.230.193.19):
Sorry for the odd title, but didn't know how to word it.
I was trying to smooth out my M, which was missing some and not responding very quickly when going from fast to slow idle, etc. I started checking timing with timing light (thought I was going crazy until I figured out that the engine was timed to #4 cylinder instead of #1).
At one point, while at low idle, the engine was starting to fall off (might have had timing retarded too much) when it kind of popped (loud noise) and the engine revved up some, accompanied by a whine/whistle noise. I shut down the engine, whine trails off as engine stops turning. Earlier I had sprayed some carb cleaner in the governor to clean gunk. Took off cover again and noticed that governor linkage was loose. Thought something had broken in there, but after checking linkage up to carb, etc., and moving throttle lever at steering wheel, tension returned to governor (no longer flopping in housing). Engine does change speed when moved from slow to fast, etc., but still doesn't want to drop down to low idle. Missing is still present.
So my question is, did my cleaning of governor remove lubrication enough to ruin bearing to cause whining noise? Or does the intake manifold have a suction leak that's producing the noise? It's hard to tell where the noise is coming from, except that it's from that side of the engine.
Any other tests to do to determine it? Sorry for the long post, just trying to get the tractor running right. Thanks for any help.
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
