Posted by charles todd on September 30, 2008 at 19:16:57 from (205.242.95.138):
I replaced my 12GPM pump with a fresh 17GPM pump on my Farmall 504 recently. I bought both pump cover gaskets (.019 and .024) and used the original gear. The gears looked good and I think I used the .019 gasket. I put in new filters and all new orings. I believe the original style filters are only good for the 12GPM pump. I called (Precision Products?) who make a spacer that allows use of a larger, modern filter that can handle the flow, but is backordered.
I have said this to get to the problem. When running there is a high pitched whine that sounds like it is comming from the flow divider.
I had my father listen to it and he thinks it is from the increased turbulent flow though the rubber hydraulic hose (not stock) causing the noise. I think it may be the gear mesh is too tight transmitting the sound up the hose. Or it could be the flow divider some how resonating? Or the pump is starving with the smaller filters...
Is this normal or acceptable with a new pump? The hydraulics are FAST and the steering works much better. It just has a whine now.
I know Hugh, Allan, Rusty and the like can probably help here.
Thanks and I apoligize in advance for the long post,
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction,
... [Read Article]
