1066 PTO Noise - Update
Posted by mjs on October 06, 2008 at 17:32:18 from (208.114.35.15):
Measured end of pto shaft to center of hitchpin on baler and it is 15 inches. The book says 16 inches needed. Put tractor/baler in tight enough turn(maybe 40% as tight as a full turn) and engaged pto and got the noise I was hearing in the hay field. Got out to listen and pretty sure it is coming from baler driveshaft. It did shorten up about 2 to 2.5 inches when I turned but didn't bottom out. Still had about 1 to 1.5 inches. I think the conclusion is to lengthen out the drawbar but problem here. My drawbar only has 2 holes up underneath and they are about 8 inches apart. If I lengthened out the drawbar, I'm afraid the pto shaft will be extended too far. Am I wrong? The only thing I can think to do is remove the drawbar and have another hole between existing ones milled into it. What are you guys thoughts?
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
