IF it's all standard 6volt wiring, the tractor shouldn't be charging the battery backwards. If the battery is disconnected, the generator will lose its polarity and won't charge the batttery until it is repolarized after the battery is hooked back up, and will only polarize in the correct poplarity. To polarize, you need just a jumper or a short piece of insulated wire (so you don't accidentally ground something out!) with the ends stripped back just enough to give you contact. Withthe battery connected and the tractor off, all it takes is a momentary touch between the BAT and GEN terminals on your relay or regulator, which should give you a small harmless spark. That's all there is to it, and the generator, if everything is working, it will charge the battery with the correct polarity. This needs to be done after any time the genrator, the battery or the relay/regulator has been disconnected.
If the battery is flat and you're asking about whether your buddy should hook up a charger backwards because of the positive ground, the answer is NO!!! just as Glennster said. + to + and - to - between the charger and the battery.
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
