Positive ground from the factory. Does it have a distributor with a coil on top? If it does, look at the wire connected to the terminal on the distributor, the other end of the wire goes onto the coil. If the wire is connected to the negative terminal on the coil, it is negative ground, if it is connected to the positive terminal on the coil, it is positive ground. If the tractor won't run with the battery hooked up correctly, replace the coil. If you have a magneto, you have a different problem. I think if it sat for a couple years, the needle n the carb may be sticking. Check the carb and make sure there is a good flow of fuel into the bowl.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
