YOURE BOTH WRONG.....but hes a bit more right then you are, read on:
First of all (where youre wrong), To run the "Motor Test" you apply voltage TO THE ARMATURE TERMINAL AND CASE GROUND NOTTTTTTTTTTT THE FIELD TERMINAL.
HERES THE CORRECT COMPLETE MOTOR TEST AND IFFFFFFF IT PASSES BOTH PORTIONS IT WILL MOSTY LIKELY CHARGE
1) First jump the FLD post to case ground,,,,,Apply battery voltage to the ARM terminal and case ground, IF IT SPINS NICE N SMOOTH N EVEN AND THE ARMATURE ISNT DRAGGING THE FIELD POLES the Armature and Brushes and Bushings are likely okay........
2) With it running unground the FLD post and it should speed up some,,,,,IF IT SPEEDS UP SOME THE FIELD WINDINGS ARE LIKELY OKAY
Today's Featured Article - The River Tractor - by Charlie English Jr.. This is a 4010 John Deere that was used to farm on the Diamond Island which is in the Ohio River about 15 miles southwest of Evansville, Indiana. About ten years ago, this tractor was parked close to the bank as the river was washing the bank of the island away.
... [Read Article]
Latest Ad:
1945 Farmall wide body gas with pto and front plow. Runs good but needs new points.
[More Ads]
