Re: 301C Engine
Posted by rich4 on November 09, 2008 at 22:26:24 from (74.60.110.90):
In Reply to: 301C Engine posted by 460 Man on November 09, 2008 at 11:01:12:
Check valve settings as said. If you cannot get the correct valve clearances, then shorter push rods. Good you did not torque it down yet. One thing to do is to put a small amount of non sticky putty on top of the pistons and turn it over by crank if possible and see what the minimum clearances are between the piston/head/valves. The cam also has to be in the right timing. .120 is a lot of shaving in my mind, but what do I know. There should be specs about minimum piston to valve clearance you need to maintain. Otherwise at high rpm they collide.
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want … unless you own a monster tractor. U ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
