Re: head gasket leaking
Posted by JanicholsonCant beat that on November 16, 2008 at 11:43:47 from (66.173.50.53):
In Reply to: head gasket leaking posted by 1938 F20 on November 16, 2008 at 08:53:36:
Well if it is running, it is in darn good shape, and all issues are small! The leak is not normal but common. Don't look too close at your other vehicles, they also leak. You can try retorquing, If it were mine, I would break each bolt loose just enough to free it, then retorque to specification, no more. Keep track of the bolt head location (mark the head to locate the rotation). if the process tightens then a bit, keep doing it. If they remain at the same turn of bolt, or less, turn them to that original mark. Do this one bolt at a time, not all at once. If it still leaks (probable) put on a new gasket and use copper coat spray on both sides of the gasket and let it get very near to dry befor assembly. (a milling of the head .050" won't hurt it either) JimN
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
