Re: 6V starter in cold weather
Posted by Idaho Ron on November 27, 2008 at 06:28:15 from (208.98.173.2):
In Reply to: 6V starter in cold weather posted by 1942 A doesn't like cold on November 26, 2008 at 14:20:23:
When I got my SC I had the same problem. I took every wire connection on the whole tractor and checked it with an OHM meter. I found that almost every connection had a little trouble. I took every connection apart and cleaned them. Then I took the started apart and used a wire brush and a can of electrical cleaner and all I did was clean everything inside the starter. In fact it took me two cans of cleaner. I put it together and it worked perfectly just like new. Now I can start it even bellow zero and it fires right up.
I also have a 41 A / 49 SA hybrid that has a Mag but no other electrical stuff, besides a starter. It has only started with a hand crank for the last 30 years that I know of. I took the starter off of it and cleaned it like I did the SC and now it will start with the starter.
To make a long story long, I think you should go through the electrical system, clean it good and take the starter apart and clean it. I think you will be pleased at how well it will work by just cleaning it. Ron
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
