You probably just broke one or both "ears" off that make the slot you use to screw it out. Dave is right as long as the opening is clean it should run fine. I had my H carb open and found one of the ears broken off. I drilled it out with a tiny bit (don't recall the size) and put the smallest easy out you can get in it. It had a little varnish around the threads but came out fine. I put the new jet back in, and couldn't tell a bit of difference - but I bet I dropped $25 into the drill bit, easy out and new jet.
If the opening isn't buggered up I'd leave it alone. My 2 cents.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
