Posted by Jim Becker on December 18, 2008 at 09:36:03 from (71.252.139.51):
In Reply to: Soldering advice posted by DRC on December 18, 2008 at 08:45:40:
I suggest that when you try it, you have the radiator filled with coolant up to the point where the core is completely filled and the liquid is just into the bottom of the upper tank. Do not have it high enough to cover the back side of where you need to solder the bracket to the tank.
The coolant will keep the areas that don't need repair from coming unsoldered. If the coolant is too high in the tank, you will not be able to get enough heat into the areas that you are repairing.
You can add more coolant before working on the overflow tube.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
