Posted by Andy Motteberg on December 25, 2008 at 14:16:16 from (4.143.222.217):
In Reply to: Stuck Farmall BN's posted by Clarkbug on December 25, 2008 at 11:43:51:
If the cylinders had water or antifreeze in them, you need to pull the head off and check out the cylinders. Clean the rust from the cylinders. If they look okay, put PB Blaster in the cylinders, great stuff, I've freed up many engine with PB Blaster. While it is soaking, tap the starter every once in a while. I think if it had water in the cylinders, you need to rebuild the engines.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
