Posted by El Toro on December 25, 2008 at 18:03:22 from (205.188.116.73):
In Reply to: Stuck Farmall BN's posted by Clarkbug on December 25, 2008 at 11:43:51:
If you have a wet or dry vacuum use it suck out all the water. You can then fill it with ATF you may need to pull the head anyway if its been stuck a long time. Those engines have wet sleeves and are not pressed into the block and you use a piece of 2 X 2 oak and a big hammer and drive on the connecting rods once you have it unbolted. The sleeve will come out or the piston. I did an A years ago that was stuck. Pulled the engine since its easier to work on. It needed the block cleaned too. I think I got the pistons and sleeves out the same day I got it home. That tractor hadn't seen a shed since it rolled off the assembly line. This was in 1975 and 1976 before I had it running and painted. Needed rims, tires, wiring, steering wheel and fenders. The engine was the easiest to fix with a new sleeve kit. crankshaft polished, new bearings and head redone. I put in all new valves, guides and springs. I had the clutch disc redone at a brake shop. Hal
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
