Not a good idea. Just like you should never fill a hot eninge with cold water unless it is running or you can/will crack the block. So filling an engine with hot water and its cold can/will crack a block. Now if you could say hook up an water heater to it and start with cold water and then turn on the water heater so it heated up the engine slowly yes that could work. I have tried to figure out how to do that but so far the problem is how to fill and keep things as they need to be and be safe and hot enough to do any good. I.E. you would need to have the water up to around 200 plus degrees to do much good
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
