Carsinslid: Much better, however 3 days ago a lady called Carla posted these same numbers on another forum I take part in, then never bothered to answer any questions that could narrow the tractor ID.
Right here you've done much better, steering shaft along right side of engine, plus the part numbers you are qouting narrows it down to A, B or Super A. Don't get carried away thinking you need photos. Is this mower lifted by hydraulics mounted below the fuel tank. When I said brake pedal curve I meant from side on. Tire sizes should be stamped in side of tires.
One other item does your tractor look like this. Look closely, I have some more questions.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
