Posted by Old-F20 on January 14, 2009 at 11:08:59 from (71.7.98.117):
In Reply to: Road Gear on F Series posted by mkirsch on January 14, 2009 at 10:24:30:
cumminsF-20 said: (quoted from post at 11:53:48 01/14/09) They did make F-20s with a road gear from the factory. If you find a tractor that you like just look at the shifter for the gear marking. Forth gear will be where third normally was (up and to the right). I cannot remember what the speed is in this gear, but I run one for years with this option and it seems to be fast enough.
R 4
1 3 2
back then it was probably a road gear, but its only good for about 7-8 mph wide open. Put a HIESLER O/D in front of it, and you'll be pushin around 18mph :shock:
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
