No No, somebody gave you some miss information. The factory high speed set up is 6 mph 4th or there abouts. The reason 3 & 4 are switched is that they put 4th gear in place of 2nd and moved reverse to the other shaft which gives it a higher reverse too. I might be off on my gear sequence but it's something like that. Anyhow most of the after market road boxes drive with the transmission in neutral. There are a few true overdrives out there too,
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
