Posted by LenNH on January 14, 2009 at 18:12:34 from (71.235.191.159):
In Reply to: Road Gear on F Series posted by Tom Stork on January 14, 2009 at 10:24:30:
After rubber tires became common on tractors, IHC offered high-speed gears for all the F-series. It is true that 7 or 8 mph is not very fast compared to some other tractors, like the H and M, but I can tell you something from my experience. I always thought the H and M were too fast for a tricycle-type tractor. There must not have been much caster or camber in those front wheels (as a writer here says about the F-20), because there was lots of side-to-side wobble of the wheels on any kind of rough surface, especially, I think, after the steering gear got worn. It was always exciting to be roaring down the road like a sports car, but when I grew up a bit and got a little wiser, it made me uneasy to go so fast with wobbly front wheels. The other factor to consider is that 8 mph is a lot more useful on a farm than the 17 or 18 that the H and M would do. The H, especially, would not pull much of anything in 5th gear down around 6 mph (approximately engine idle speed--not much torque), about the top speed on a gravel road with a loaded wagon, especially one on steel tires like a lot of people still had in the 40s. I always wished that IHC had done what Oliver and JD did--put in six gears, with one fairly fast (around 12 mph in both cases), and one just a bit slower (around 8 mph) for pulling heavy loads over country roads. Obviously, if you are going long distances with a tractor, it is nice to be able to slide along faster than 7 or 8 mph. One of the things you'd find with a 7-8 mph gear is that you could throttle it back a bit for light work at maybe 4-5 mph, not have to make so much noise, cut down on engine wear, etc. Same goes for traveling over the trails between fields.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
