Sounds like you have original set up. Remove the plate or bracket under housing and see if mounting bolt is tight broken or missing. If I remember right its a 5/8 dia. bolt. Probably 7/8 or 15/16 wrench head. Bolt screws up into the piece with hex on it. As others said its solid except for taped bolt hole and 1 inch pipe threads on outside. Should have a special contoured washer under bolt head to match contour inside housing. Return fluid exiting bottom of valve goes back into suction hose to pump. Hose should be passing through tee fitting above tee your remote valve goes into. For the remote control valve to work if hoses are in original locations the lever on unit under tank has to be locked in rear position. For the unit under tank to operate single acting hydraulics the other valve has to be locked closed. Good luck
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
