Re: mccormik deering 10-20
Posted by LenNH on January 23, 2009 at 14:54:18 from (71.235.191.159):
In Reply to: mccormik deering 10-20 posted by DAN DOYLE on January 23, 2009 at 13:25:14:
The head is pretty similar to most simple engines. Valve rockers off, push rods out, cylinder head nuts removed, pull the head. The head slips over long bolts that appear to be screwed into the block. I'm looking at a repair manual that my grandfather got when he bought the '29 10-20 I "grew up on."
If the carb is the original sidedraft type, it is similar to the carb on a "Regular Farmall." There were aftermarket manifolds available in the 30s and 40s to convert to gasoline, so there is at least the possibility that the setup isn't original.
This manual is not very detailed, but I'd be glad to consult it for you if you e-mail me.
There are no torque figures, so I guess with these old hunks of iron, you just did your best to get even tightening on the head.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
