Re: 1086 power beyond block needed
Posted by pete 23 on January 29, 2009 at 11:00:49 from (173.87.1.12):
In Reply to: 1086 power beyond block needed posted by Ralph Butteris on January 29, 2009 at 07:58:47:
I am assuming you have the open center system other wise with the pfc system closed center this doesn't work. You need to hook the supercharge line coming out of your aux valve bank into your added valve , go right through while valve is in neutral and back to supercharge line going to mcv pumnp, then have to have a port in valve bank for return flow from valve when in use to return to sump so as not to contaminate super charge line with anything in return flow. A CaseIh dealer should be able to print you a copy of service bulletin S-3436 Dated March 1977 from hydraulic section. It lays it out for you along with options to run an orbit motor. Gets to be kind of a mess but does work.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
