Posted by pete 23 on February 08, 2009 at 11:54:36 from (173.87.1.12):
In Reply to: more fuel posted by LIVIN LUCKY on February 08, 2009 at 10:59:14:
There is a torque screw on rear or back side of injection pump depending on vintage of pump. This will most likely do very little or nothing but you can try turning it out a half turn or so. The main adjustment is of the leaf spring controlling the maximum movement of the pumping plunger inside and requires some dissassembling of the pump. Have to remove cover, metering valve guide stud and governor linkage. Then turn engine to see allen screw on leaf spring and turn it in a tad. Like maybe a quarter turn max.Then on reassembly, the automatic load advance will need to be adjusted. Not a job to be taken lightly as a runnaway engine could result. You may have low fuel pressure due to worn primary pump or regulator valve so the pressure should be checked before any adjustments are made. I will assume fuel filters and flow through hose at pump are good.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
