Jim: I'm not sure you resolved this. What serial numbers were the last Service Products fans used, both SA and SC. You are presenting us with a water pump fan and non water pump fan for the Schwitzer-Cummins. Why would one brand do all yet the other brand required two separate fans.
Looking at my SA fan the pitch is much more agressive than 130 and 140. Driving the three tractors I quite regularly feel the breeze from SA fan. Very rarely have I ever got a breeze from 130 or 140 fan. Now, I realize the 140 is a whole different setup. Given the fact that SA sheet metal is 2" closer to chassis, I would expect that to block air flow somewhat to operator platform. There could also be another factor, my Super A is one of the roughly 20,000 SA with pressurized thermosyphon.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
