Re: Next tire question
Posted by Randy-IA on February 15, 2009 at 11:07:07 from (207.177.83.123):
In Reply to: Re: Next tire question posted by charles todd on February 14, 2009 at 21:12:29:
Hi Charles . I'm by far NOT an expert on front ends so I might be totally wrong here but if you have negative rake I believe you might have a problem. The spindles vertical axis should point in front of the wheels true vertical axis at the contact patch by a small amount to get the self centering action out of a turn. To much and it's hard to turn , to little and it's hard to keep straight.
That looks like a brand new loader. NICE!
Thanks for the reply! ...Randy
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
