Sounds like she lost prime on the MCV pump. But to be dure here make sure that the three point goes up and down . IF that works then run the engine at around 2000 RPM and if the steerwheel is free floating then turn the steering wheel to the left as this will help bleed the air out of the system and help it pick up prime . Got to remember she is getting old and i'll bet you don't pick up prime to fast anymore either.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp
... [Read Article]
