Re: Speakin' of plowing and tires ? for all master plowmen
Posted by IH fan on February 15, 2009 at 18:06:21 from (70.245.163.21):
In Reply to: Speakin' of plowing and tires ? for all master plowmen posted by Randy-IA on February 15, 2009 at 12:02:37:
Another thing to consider here is actual tire width... does the 18.4 actually have that much on the ground... I remember when they started the new numbering system... 12" became 13.6, 13" became 15.5, etc... were the new numbers the "actual" width?
I would also think it hard to set up some plows to pull right "on land"... it can't be good to have your tractor drawbar locked over to one side and still pull straight.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
