Posted by pete 23 on February 20, 2009 at 10:34:19 from (173.87.1.12):
In Reply to: framall 350 hyd posted by t lyon on February 19, 2009 at 17:32:37:
First thing to look at is if some one has turned the single , double selector too far and bent or broke the roll pin stop as this will cause system to stay on demand. Second, in the regulator valve block,(one with four bolts on top) there is a screwed in orfice with a screen that will plug causing same problem. You will need a new gasket and maybe orfice as screen gets tore up bad. Cut off bottom of screen to clean and then curl it back up if it is intact. Put in a longer bolt in opposite corners of block when removing cover as there is a very heavy relief valve spring under neath.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
