Re: Here's a crazy thought... gas manifold with shield an...
Posted by Paul G. In Mn on April 20, 2009 at 15:34:42 from (206.183.178.233):
In Reply to: Re: Here's a crazy thought... gas manifold with shield an... posted by Mike CA on April 20, 2009 at 07:26:17:
What I did was took the gas manifold off the tractor and had the heat shield to set over top. I then got it all centered and marked the 2 top holes. I then drilled and taped the manifold I believe 3/8-16. I made up some treaded rods and screwed them into the intake. I put a nut on the rod and tighted to the mainfold leave enough room for the shield and anther nut. Once you have that set tighten and mark out the bottem hole and do the same. I added a flat washer against the shield on the bottem on both sides since its sloted. It seems to be working nice on my M and gives it the right look. Paul
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
