If you want the theory behind the Delco 10si (which is likely the alternator your dealer gave you, do a google search for "alternator theory V15.0" Our 806D was converted to gen to a 1-Wire Alternator by a previous owner.I just converted it to a 3 wire so it matches our 966. Below is an excerpt from a post I had made here a year or so ago regarding the rewiring. I like this method better than the resistor, as it allows you to use the stock AMP light in the gauge cluster.
"I took a look at how the one wire alternator is wired in last night. He ran a wire from the Batt terminal on the alternator to the solenoid. From there is a wire that goes through a small circuit breaker to a box to run our round baler tying control. There is a battery cable running to the batteries (two 12 volts wired in parallel), and a wire that runs up into the factory wire loom to power the gauges, lights, key switch and added voltage gauge. To put a three wire alternator in, I want to run an 8 ga. wire from the alt. to the solenoid (the old wire is about 10 or 12 ga.). Then run a 16 ga. wire from the 1 terminal on the alternator to the original factory amperage idiot light and then to the key switch. Then run a 16 ga. wire from the 2 terminal to the batt terminal on the alternator."
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
