Posted by ScottyHOMEy on April 29, 2009 at 15:08:21 from (70.105.244.253):
In Reply to: farmall super c gas posted by mitchfarmallsuperc on April 29, 2009 at 13:30:10:
If it's right under the fuel tank, that's what's called a sediment bowl. The float bowl is the bowl of the carburetor.
They're pretty readily available through most parts outlets.
It's sometimes hard to tell where the leak is coming from. It could be the thread between the bowl assembly and the tank but usually isn't. More common is for it to be the gasket between the glass and the meatal, or around the valve stem.
Before going looking for a new one or a gasket, you might try just tightening the compression nut, which is the hex nut that would appear to surround the stem (the part you're turning) of the valve. It won't go far or take much, and you may find that all you've accomplished is to make it so tight that you can't turn the valve and that it still leaks. If that's the case, you can learn how to repack the valve (quite simple actually and a neat little project, and while you're at it would be a good time to replace the bowl gasket and the screen inside the top of the bowl) or go ahead and thread a whole new bowl assembly in.
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
