Your analysis of the field coil connection through the regulator is correct. Voltage feeds the field coils from the armature end of the coil and exits at F terminal to the regulator. The regulator contact is closed, thus grounding the field coil until generator builds sufficient voltage to open the coil, so no voltage will be seen at that point.
To Test: Jumper field terminal to ground. if this makes it charge there is a problem with regulator.
If no charge leave jumper on field terminal and jumper from ARMature to BAT on regulator. If this makes it charge you have a bad regulator, if no charge you have a generator problem.
Here is a link to a Delco-Remy bulletin which explains how the regulator works.
Today's Featured Article - Fordson Model N: Field Service Operations and Lubrication - by Anthony West. The daily or weekly servicing of any vehicle is of the utmost importance, and in days gone by when our favorite tractors were doing an important and Commercially vital job on the farm, these service operations would make a major difference to the running costs and economy of the farm. This being so, it surprises me to see how many enthusiasts attending rallies, shows etc, seem to be unaware of the importance of this constant attention. Possibly the modern machine with its 6,000 mile or even once
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
