Re: Farmall 560 Tachometer
Posted by Owen Aaland on May 13, 2009 at 17:01:31 from (65.165.246.54):
In Reply to: Farmall 560 Tachometer posted by Fredd on May 13, 2009 at 16:46:51:
They all rotate the same direction. It makes no difference whether it is gas or diesel, the same part number is listed for both.
There are different part numbers listed for 460 versus 560 so I would guess they have different face plates. Probably different MPH versus engine RPM.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
