Re: Farmall Super A steering loose
Posted by Tom Fleming on May 16, 2009 at 12:16:36 from (67.20.245.118):
In Reply to: Farmall Super A steering loose posted by aretus on May 12, 2009 at 11:27:30:
I had the same symptom, but my problem was a bit different. The gearbox lash was fine. Tie rods were fine. What I found was that the center tie rod arm was loose on the vertial shaft. Appears to have been run over the years with the bolt loose. soooooo, I cleaned it all up, used 2 GM starter motor shims, trimmed to fit the square, new bolt, and it is fixed. I placed the shims on the front 2 flats of the arm, with a short lip on the top to hold in place. These shims were .020 each. I only had to drop the axel, and not the whole gear box (which is a good thing).
No more slop in the steering except for the "normal" lash.
If you are lucky, your problem may be the same.
Took me 2 hours from start to finish to repair including the trip to NAPA to get the GM starter shims............
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
