Posted by PRTZMAN55 on May 22, 2009 at 05:36:52 from (67.234.225.67):
Morning All, I need your help with a question about mowing with my IH cub. Its a 67 with a IH mower driven by the power take off pulley. Does the pulley turn at the same rpm all the time ? My grass is getting high and the ground is starting to dry up so now is a good time to mow. In the shorter grass it does ok but it deeper grass it wants to bogg down. MY reaction is to throttle up but that make it go faster, if up press in the clutch it will stop. If you were to run at lower engine rpm s will the mower still go as fast as it would at higher engine rmp . I guess my question is does the pto pulley run at the same rmp all the time ? thanks for your replys Harry
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
