Posted by Roy Ward on May 22, 2009 at 17:32:08 from (66.82.9.74):
In Reply to: Farmall C Carb posted by Eric Phipps on May 22, 2009 at 14:22:07:
Could be several things. May not be fuel at all. Coil are condenser. Condensers get leaky from setting. Coils are not to bad about it. A condenser will short to ground a kill your spark when they get hot. I would take the Carb back down and blow it out again making sure there is nothing in the bowl but but bright metal. Check the float I had one hang on a new gasket and had to trim the gasket.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp
... [Read Article]
