Re: Charging Problem 2444 IH
Posted by Owen Aaland on May 22, 2009 at 20:48:06 from (65.165.246.54):
In Reply to: Charging Problem 2444 IH posted by Janicholson on May 22, 2009 at 20:13:07:
Janicholson said: (quoted from post at 20:13:07 05/22/09) Both VRs may be bad. There are good new VRs on the market, they cost a bit more, but work well and longer. The field winding is grounded to make full output. Thus the F terminal on the Regulator leads to ground through the regulator frame. Testing it is a good idea. Keep us informed. JimN
The 2444 should have a 10DN series AC generator, better know an as alternator.
The regulator has internal connections to both battery voltage and ground. The field circuit of the alternator is internally grounded and needs voltage from the regulator applied to the F terminal to charge. Either grounding or applying battery voltage to the field circuit while the regulator is connected can fry the contacts in the regulator.
Poor or missing grounding at the regulator can lead to overcharging.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
