Re: Farmall C compression problems
Posted by Roy Ward on May 23, 2009 at 19:03:12 from (66.82.9.56):
In Reply to: Re: Farmall C compression problems posted by Roy Ward on May 23, 2009 at 18:56:53:
I forgot to answer the other question. If your test results show valve problems. Pull the head and fix it don't run it. You will burn out your valve seats. It may be just burned valves and some times you can just lap them.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
