Posted by CNKS on May 24, 2009 at 17:49:05 from (216.144.104.128):
In Reply to: model h # fbn107526 posted by Roy E. Mchenry on May 24, 2009 at 14:47:26:
Carb kits are available about anywhere, all the way from CaseIH to this site -- CaseIH is the most expensive. You might check the screen which is inside the fitting on the carb that you removed the fuel line from. If that is clean, disassemble the carb, let it soak for a while in true carb cleaner (preferably overnight) and blow out all passages with compressed air. Also, you said you cleaned the lines -- you might also want to check the opening in the tank that goes to the sediment bowl. That is a very common plugging area.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
