Re: 866 no hot start
Posted by Allan In NE on May 25, 2009 at 03:23:38 from (148.78.100.118):
In Reply to: 866 no hot start posted by Plant Doc on May 24, 2009 at 16:30:15:
"IF" it starts just fine when cold, you are either starving for air or it's starving for fuel when warm.
Check all filters first.
If they are okay and especially so if the tractor will not run well at low rpms, problem is in the injector pump as Cole mentioned.
Allan
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
